oil line things..
Started by richrx, June 13, 2009, 11:20:28 PM
richrx
hi
sorry for the poor images and descriptions :p but any idea where to get replacement oil lines? these run from under the air pump, probably the oil pump but im not going out to double check. its too late :Hammer and connect to the inlet manifold? there brittle plastic and have snapped :(
one end has banjo bolts the other is slightly flaired
the proper name would be of help too
thanks for bearing with me! :Snoring
rik
pdtaylor18
those are the OMP lines and do go very brittle. Do not use any old tubing as it will go soft with the heat. I replaced mine with braided hose.
Email: pdtaylor18@hotmail.com
Pete[SIGPIC][/SIGPIC]
richrx
where did you get them?
im gonna check my local car shop see what they can di. i suspect not alot tho, fc\'s are too rare now  :Laugh
rik
sheprx7
Quote from: richrx;616232where did you get them?
rik
haha too true! i went to my local car shop the other day and one of the guys that worked there looked out the window and said \'is that old porsche yours?\' :rollin:rollin
pdtaylor18
I may have some of the braided stuff left but you will need to have your old banjo\'s and you will also need a bit of heat to weld them to banjo union (just gives a better seal for the plastic. You will also need your old clamps,they are important.
I will see what I have and cost,but it will not be much.
