Crunch on gearbox - FD3?
Started by suba, June 18, 2009, 12:45:26 PM
suba
When cold the gearbox on my FD3 seems to be a bit \'off\' when going from 1st to 2nd occasionally - not all the time.  Once in a while it does it from 2nd to 3rd as well.  No grinding noise, but does not pop into gear smoothly.
The gearbox oil is new - I\'m guessing this is down to worn synchro?  (box has done 85,000 miles or so) and not had massive power put through it...
I\'m tempted to wait until it gets worse, but the clutch is going to be changed soon anyway, so would make sense to do the gearbox too if it\'s going to need doing....
Single Turbo time!
ianelvar
Does it happen when you\'re ragging it, or in normal driving too? Does the clutch bite close to the floor or really high? I had that trouble when my pressure plate was past its best and wouldn\'t release fully, but it was only a major problem when I was shifting at high RPM. I have a gearbox for sale if you do need one
suba
rpm does not seem to make much difference, but the clutch does seem to bite a little high.  It a standard clutch - now I am wondering if running 0.8 bar (was 0.7 when  I got the car 3 months ago) has pushed the clutch a bit much, though I would have thought that this would be indicated by it slipping - and there is not even a hint of slip.:xconfused
I do have a single plate clutch on the way and Atomic Rex have offered to re-build my gearbox when the clutch is done, so this might be the best option for me I guess.  If it turns out that I need a box then I\'ll give you a shout.
Single Turbo time!
trevtubby
I always thought that a notchy gear change into 2nd when cold is quite normal on a lot of fd`s.
QuoteImpossible is just a big word thrown around by small men who find it easier to live in the world they’ve been given than to explore the power they have to change it. Impossible is not a fact. It’s an opinion. Impossible is not a declaration. It’s a dare. Impossible is potential. Impossible is temporary. Impossible is nothing.
Contact me on: trevisbest@hotmail.com :)
suba
Honestly - I dont know.  This is my first FD.:confused:
Single Turbo time!
