wastegate plumbing?
Started by col_fd3s, June 15, 2009, 08:14:45 PM
col_fd3s
hi guys, i\'m having drama\'s with my wastegate plumbing.
the rear pipe on my wastegate comes up and into the boost controller, then off into the upper inlet manifold, however the front pipe on my wastegate is just hanging loose and i can\'t for the life of me find where it goes..., any idea\'s?
i don\'t have the instuctions and the other port on the uim is taken up by my ssqv.
any help greatly appreciated as i really need this back on the road tonight.
col
gonzoninja
I think I routed my pipe round to the front of the UIM, there are four nipples here which you can get a take off from. The other ones are an oil pipe from the Oil filler, the other is from one of the solenoids left and the other two should be free (assuming you\'ve gone single and removed all the other solenoids)
