Car Battery Connectors..
Started by Retro_Boy_G, June 09, 2009, 12:39:18 AM
Retro_Boy_G
Hey guys,
How is everyone.. Right, for the past 6 months i have believed that my alternator has been rooked.. Well, tonight it seems it might not have been this afterall.. The other night i went to start the car and it started fine but then just died a death.. the whole electrics went. Pushed it out tonight to charge the battery and pushed the battery connectors in and all the power came back on..
I noticed ages ago that one connection was cracked but thought it should be ok.. I\'m now convinced that it is this that is making it look like my battery keeps dying.
Has anyone ever had to change the connectors before and can anyone tell me how to do it and where to get them.. I\'ve seen them on eBay for very cheap but wasn\'t sure if they were car specific.
If anyone can help me out that would be appreciated! :)
Gianni
dthebuk
the connectors that connect to the battery terminals right? I have 2 new spare ones you can have if you want. They re simple to change, you\'ll need some sort or wire strippers though.
:burnout
Retro_Boy_G
Hello Jemes!
It\'s pretty much these things i need.. (but not these ones)
http://cgi.ebay.co.uk/Car-van-HGV-battery-terminal-kit-1-pos-1-neg-connector_W0QQitemZ320366203747QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item4a97505363&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1683|240%3A1318|301%3A0|293%3A1|294%3A50
The thing is, the wire going to the battery points aren\'t very long and i don\'t know if i will be able to cut any wire away.. I will take them anyways dude as i\'m sure i can sort something.
dthebuk
yea they\'re new ones the aa man gave me. you should try and use a bit of newly stripped wire, and remember to use copper grease on the terminals
:burnout
I changed mine for some Halfords ones, as mine had also split.   If they are the original connectors, then they are made of lead and will melt right off the end of the wire - but be careful not to set fire to the insulation.
I\'d also advise pulling the battery and sticking an old metal container in there so that the molten lead has somewhere safe to drip. :)
dthebuk
gianna if you wanna send us your address ill get onto posting them tomorrow
:burnout
