whats just right
Started by Jas, May 20, 2009, 08:36:43 PM
Jas
Will you gain or lose topend or lowend speed with or with out a rear spoiler
pluss wheels is bigger better a 18" or smaller like 15" with depper tyer pros and cons
or is it just looks
can you help with this
Jas
An obsession was just the start.
probedb
At the speeds you\'re likely to be going I don\'t think most spoilers will do that much.
As for wheels it\'s up to you, bigger than 18s is probably a no no for handling. Also make sure they\'re as light as possible.
Timmy
The stock spoiler reduces rear end lift, the car becomes unstable at high speeds without it, it also tidies the airflow and reduces the drag.
Aftermarket one sometimes are fuctional some are purely for show.
17" wheels i think are considered the best for performance.
jackaleks
i\'ve had mine up to 140-150 on open road (my private open road, of course) with no stability problems. i have no wing and 255/45/17 tyres on the rear.
chrisJDM
im sure i read somewhere that 90% of spoilers dont do jack unless you are doing 150+
Bobbit
the stock spoiler does nothing unless you have a later spec one. I\'ve seen the wool test (bits of wool tped to a car and then photos are taken when the car is moving, the air moves the wool so you can "see" the air flow over the car as the wool moves) on the FD and the 93 spec spoiler is useless.
:Laugh LOL
Jas
so looking at it guess 17" stagerd lite wheels and something like the rz spoiler is the way to go
chrisJDM
yeh lightweight 17\'s would be the best way to go :Thumbsup!
