Cuts out when warm
Started by mikemike180, May 22, 2009, 08:04:27 AM
mikemike180
Hi guys
Can anyone advice me on why she\'s cutting out after she warmed up, it seems to be after about 20 minutes of driving that if i put the clutch down she just cuts out.
Mike
jackaleks
have you had a compression check recently?
nikp
Check the idle controls - idle valve plugged in? Throttle body and air bleed valvle adjusted correctly?
When cold there is a cold start system that will see elevated revs. Then, once warmed up this is no longer used, and the standard idle system will kick in. If this is not adjusted properly, it could explain your issue.
mikemike180
Quote from: nikp;610004Check the idle controls - idle valve plugged in? Throttle body and air bleed valvle adjusted correctly?
Sounds promising, i\'ll give it a try
Thanks mate
leon
Clutch switch too could be an issue :Hammer
I woof in your general direction.
mikemike180
Whats the best way to do this
