Help!! sudden engine trouble when adj pfc.
Started by AndersE, June 05, 2009, 09:56:25 PM
AndersE
I read the pfc faq about adjusting ignition timing and fuel correction for running on 95 octane fuel.
I decreased IGN corr to -7 as said in the faq, then increased INJ corr a couple of steps.
I did not notice any change in running (this was on cold engine) and when
accellerated warmup was finished after a couple of minutes the engine suddenly started to limp as "running on 2 cylinders;)".
Or it just happened to coincide when acc wamup was complete, i don\'t know.
I quickly turned off engine and ignition, tried a while later and it still "limps".
The corrections in pfc are reset after power off, so it\'s not that.
The engine was only running maybe 5minutes in total and i have no problems starting it again, it just won\'t idle..
AndersE
happy happy joy joy..
nothing wrong with my engine, just pfc was ....ed up. I reset settings and relearned idle, now it runs as it should.
Lots of black smoke and exhaust bangs for a minute after that, then it cleared off, and now everything is a-ok.
So there seems to be som bugs in my pfc as even a power off and disconnected battery those temporary settings did not go away even if they were zeroed out on the display.
shaunwil
How far away is a tuner ?? Would be a good idea to get the car tuned on the pfc. The base map is good up to a point with some small modifications on fuel.
Where was the FAQ that told you to adjust the pfc ??
Shaun
AndersE
shaunwil
Please make sure if you are reading FAQ they are off rotary forums. Its a completely different animal to a piston engine and can end in some serious headaches and engine failures !!!
Shaun
AndersE
#5
shaunwil
