Another little question...Wiring
Started by N22CK_C, June 04, 2009, 01:24:12 PM
N22CK_C
Yes me again..
Just as quick solution to my little flooding problem..i was going to wire switch into the fuel pump... so i can turn it off..:yes
just as quick look there is four wires going into the fuel pump anyone know the colour of the wire which is the "live" so i can put switch in?
Nick :Thumbs-up
two of the wires are slighly thicker - these are for the pump.  The other two are for the fuel level sensor.
Can\'t recall the colours off the top of my head, but they all looked black with coloured stripe to indicate which was which.
grinder
it works wonders - i had the same on the egi
when you come to stop the car - park up - flick switch and when the rev flutter turn it off
i never let mine stop byitself ( dont like the idea of tooo much fuel starvation )
The tightest man on earth
:Giggle
N22CK_C
Quote from: Prof;613352two of the wires are slighly thicker - these are for the pump.  The other two are for the fuel level sensor.
I\'m guessing that it will be solid black that which i could put a swtich in...
Spartacus
It shouldn\'t matter if it\'s the power or earth as it will have the same effect.
