what cluch for 350BHP FD
Started by michaelb, May 23, 2009, 03:10:09 PM
michaelb
Hi All
I will be changing my clutch very soon.  I have had it for 3 years and I think that it may be on its way out
I can have the stock mazda clutch for around £260 inc or I have been told that Exedy clutch is better but it is much more expensive
I have well modified twin turbo producing around 350 BHP
Can I still use the stock clutch with the above power or would I benefit with a better clutch system and is it really worth spending more money if the stock clutch can handle my power.  Do you really pay more for longer lasting clutch or do you actually get better acceleration / take of ect
I don’t take the car on the track but occasionally burn off other cars on private rds, like a mini drag race…
Can any one recommend a better clutch which isn’t that much more then stock one?
Regards,
Michaelb
turbo boy
They come with an exedy clutch as standard. Mine has around 320ish and i went for an exedy stage 2 clutch which i brought from mazda rotary parts at around £400. They can handle over 400+ and is driver friendly. Hope this helps.
turbotoaster
mines an exedy clutch that i got from WGT, its rated for 350ft/lb and was £375, ive come from a standard worn out clutch to this and its taking a bit of time to get to used to but seems a good choice in my opinion, id go for that as then you will know you are covered for anything
John_Hudson
michaelb
Quote from: turbo boy;610316They come with an exedy clutch as standard. Mine has around 320ish and i went for an exedy stage 2 clutch which i brought from mazda rotary parts at around £400. They can handle over 400+ and is driver friendly. Hope this helps.
Hi
So what you are saying that Mazda standard cluch is actually made by exedy?
Regards,
Michaelb
michaelb
Quote from: John_Hudson;610326go for a hyper single :)
Thanks for that but what is a hyper single and how much dies it cost?
Regards,
Michaelb
michaelb
Quote from: turbotoaster;610325mines an exedy clutch that i got from WGT, its rated for 350ft/lb and was £375, ive come from a standard worn out clutch to this and its taking a bit of time to get to used to but seems a good choice in my opinion, id go for that as then you will know you are covered for anything
Thanks for that
What do you mean that you had to get useed to it?
Whas it hard to press down and a pine in trafic?
REgards,
Michaelb
Jit
If youre after something fairly cheapish and dont ind used, I have an xtreme clutch (australian company - reworx sell them) for 200...the friction plate is like new and the pressure plate is good. The pressure plate is good for about 40% more than standard (so 40% of 265 is 110 ish) so good for around 370hp
michaelb
Quote from: Jit;610511If youre after something fairly cheapish and dont ind used, I have an xtreme clutch (australian company - reworx sell them) for 200...the friction plate is like new and the pressure plate is good. The pressure plate is good for about 40% more than standard (so 40% of 265 is 110 ish) so good for around 370hp
Hi
Thanks for that
How much was it new?
Why are you selling it and how many miles has it done?
Regards,
Michaelb
Jit
Hi Michaelb
its done barely any miles...id say 2000 max?! It is 620 new from reworx. Im selling it because I didnt think it would handle the 450 or so hp that my FD was putting out so I thought better to sell it than to fit it and burn it out!
If you send me your email, ill drop you some pics over
michaelb
Jit
michaelb
Quote from: Jit;610519mail sent :D
OK
Thanks for the shots, let me speak to Kerim at Powergains Motorsport ( RX7 specialist in London) and see what is his opinion on haveing a second hand cluch and I will get back to you
Regards,
Michaelb
