Fitted wheels spacers.
Started by GaseJo, May 16, 2009, 05:09:41 PM
GaseJo
Hi,
Got round to fitting wheel spacers today, I was hoping to do front & back but the rear ones have not turned up as yet..
Anyway Fronts 15mm & 25mm on rears.
As she was..
Wheel Off..
Only being 15mm The original studs needed to be cut down, So i fitted the spacer nuts to the studs for 2 reasons.
1. To give me the length the studs needed cutting to
2. Incase i damaged the thread Then when i undid the nuts it would recut the thread for me.
10 minutes later spacer fitted & wheel back on.
Fills the arch alot better.. Ohh for that extra 15mm :D
When i get the rears fitted i will put up another pic.
Cheers Garith.
James H
Just did mine too, well worth the job & money!
