Couple of fueling/modification questions
Started by matt p, May 02, 2009, 10:20:10 AM
matt p
Hi guys,
Can i pick your brains quickly:)
Ive got my engine picked up, but looking into upgrading the fuel system.
I know i need a fuel pump bosch 044 or similar and a sard FPR. Im looking into running four 850\'cc injectors would i need a KG part fuel rail to or do the
850\'s fit the standard fuel rail?
Matt
Why its good to do your homework of "specialists"
http://www.fduk.org/forum/showthread.php?t=28429
lee mills
plenty of people run with 850,s in the primaries  so it is possible. im not sure what you have to do but if you use the search button it has been covered many times
gonzoninja
I think you have to machine the primary rail down so that the 850cc injectors fit in the rail.
I think I\'ve got one of these lying around actually (changed my plans about having 850 primaries), if you\'re interested?
matt p
#3
Ahhh mr gonzo that would be cool if you still have it?.
Lee the search engine on here = epic fail every time!
Drop me an e-mail to mattp82 @ hotmail dot co dot uk
Just read your thread about the apexi, what a drain you had any luck getting your readings back?
Matt
