Losing water...
Started by mark-ashley, May 01, 2009, 10:34:21 AM
mark-ashley
Hello all...
Haven\'t been on here for a while, i trust you are all well !
Developed an annoying fault on my FD, basically, it seems near enough everytime i start the car from leaving it overnight i have to top up the water.
Whilst driving it, all is well, then i park up and have to repeat the above the next time i drive it if i have left it over night...
Easy i hear you say, you have a split pipe...
Well, the strange thing is, it doesn\'t always happen plus, on more than one occasion and now more so as i check everytime, when i park the car up after a decent run, on most occasions it looks like all the water is leaking out once the engine is shut off as opposed to leaking out over a period of time...
On one occasion, i parked up in the Shell garage in Balahm, went in to get some smokes and came out and there was a water leak trail from my car at least 6 foot in length...
Is there a thermostat or something that might be causing the cooling system to dump out all the water ?
I\'m heading down to my mates garage tomorrow to put it on the ramp and check the pipe work, any thoughts on what else it might be ?
1993 FD3S - Street port, Decat, Apexi FC, Apexi Induction - Engine rebuilt and installed by Hayward Rotary, too fast for the mean streets of Croydon !
logicalChimp
Hi
Where abouts are you topping up the water?  Only, if you top up at either of the front two caps (the AST or the overflow) you will over-fill the water, and the excess will get dumped...
The main top-up point is near the middle of the engine (iirc)...
mark-ashley
I\'m topping up in the right place, the cap has a 0.9 bar marking on it if memory serves me right, it also has the level sensor on the neck...
Definately not putting it in the AST or the overflow !
gonzoninja
Sounds simple, but do you have a hole in the overflow system.
Doesn\'t water get drawn into here under vacuum when the engine is shut-off?
I had a similar thing on my RX7 it was silicon hoses not tight enough, was fine when water was going through it, but when it was shut off water came out.
chris
a common problem is a leaky cap, the cap has a pressure and a return valve (the small silver disc), the disc getts crud building up under it and prevents a good seal, then as the water expands it seeps past. Try gently lifting the return valve and cleaning any debris off.
RobbieRX-7
Sounds like waterseal failure. Do you get lots of steam out the exhaust in the morning?
