Intake temps
Started by neil_jdmr, April 02, 2009, 10:06:54 PM
Bobbit
Sounds a plan bud, i\'m def off fri till mon, but hoping to have tue wed and thurs too, i\'ll let you know on mon fella.
:Laugh LOL
jackaleks
that\'s some nice work on the heat shield! at the least that would stop heat soak when the car is stationary i guess?
maybe if you\'ve got an aftermarket IC the higher temps from heat soak would probably be more than compensated for? there was a great thread on fd3s.net about different filter systems (stock box with panel, pods with heat shielding, open pods e.t.c.) comparing data on intake temps and hp gains, can\'t find it though.
neil_jdmr
Quote from: Bobbit;596241Sounds a plan bud, i\'m def off fri till mon, but hoping to have tue wed and thurs too, i\'ll let you know on mon fella.
Cool!!
What was JDM Allstars event like today then????
