Lifting Rex at the front - drive-on ramp suggestions
Started by Aubec, March 31, 2009, 11:06:30 AM
Aubec
Hi guys,
Just looking for some feedback on how you guys get the front end high enough to slide a hydraulic jack under your cars?
I\'m toying with some light alloy ramps like the ones on this page:
http://www.proalloy.co.uk/cgi-bin/shopwise.pl?act=sect&pt=52&s=325&id=proalloy
But £115 including delivery seems a bit steep for some folded metal - though thats a lot cheaper than Demon-Tweeks! :eek:
Thanks!
Aubec
1995 UK Silver FD
Adriansturgess
Quite expensive but do look very nice :InLove, of course you could always knock yourself something up out of a bit of old plywood (just make sure the ends of the nails are sticking down and not up though!) :chat
FD or not FD? that is the question.
SiH
Ummm, Bricks :D
Seriously, get some bits of timber and make some small ramps - Just bits og 1" thick and layer them, getting shorter as you go up. Shoul;d give you enough room to slip a ramp under.
I\'m just lazy/tight however, and i stick the scissor jack under the jacking point, pop it up a few inches, then slide the trolley under.
Aubec
#3
Quote from: Adriansturgess;595027Quite expensive but do look very nice :InLove, of course you could always knock yourself something up out of a bit of old plywood (just make sure the ends of the nails are sticking down and not up though!) :chat
Yep, expensive was my thought - I\'d rather spend the cash on mods than tools... Already blown over £1200 this month which I can\'t really afford thanks to UKGOV taking away my bonus...:Grrr
I think I\'ll give it a try on some wood and see how I get on - I like the fact the ramps have a dip at the top though to stop you from driving over the end of them though!
If anyone else knows a cheaper supplier of ramps please shout! I don\'t want those nasty halfords jobbies though - they\'re not shallow enough angled to get under the front bumper I don\'t think.
Aubec
1995 UK Silver FD
Kash_
QuoteI\'m just lazy/tight however, and i stick the scissor jack under the jacking point, pop it up a few inches, then slide the trolley under.
same here lol
Adriansturgess
Quote from: Aubec;595047I like the fact the ramps have a dip at the top though to stop you from driving over the end of them though!
Well even on the timber version you could secure a block of wood at the end of each ramp to act as a stop. Mind you they\'ll never look quite as sexy as the ones in the ad!
Aubec
Quote from: Adriansturgess;595130Well even on the timber version you could secure a block of wood at the end of each ramp to act as a stop. Mind you they\'ll never look quite as sexy as the ones in the ad!
Well yes, if I could be @rsed with making something I\'d weld my own up! :Giggle  But you got right to the point, I like the sexy alloy ramps!
I don\'t trust the sills on my car by the way, that\'s why I don\'t just scissor jack it - have a horrible vision of the jack punching through the floor!  Even when the car is on axle stands I keep a jack under the diff / crossmember so the weight is split three ways!
Does anyone have any photo\'s of their dodgy botch solutions?
Aubec
1995 UK Silver FD
leeincivic
crap pic i know but ya can see the ramps i made to get round the same problem you seem to be having:mmmm cheap and cheerful :)
THE POLICE NEVER THINK ITS AS FUNNY AS YOU DO!:Thumbs-up
HKS T51R KAI, APEXI PFC, BLITZ NUR-SPEC, WALBRO FUEL PUMP, GREDDY FMIC, SARD FPR, 1600CC INJECTORS, GREDDY ELBOW AND PULLEY KIT, MUCH BODYWORK TO BE DONE:eek:
470.2 FWHP / 405.6 RWHP / 394.3 LB/FT    AT 1BAR :Laugh
BRIDGE PORT AND REBUILD TO COME:3gears-rh
SiH
Dude, not sure if you know, but you\'ve got a small leak out the bottom of your rad :(
leeincivic
trotter
I\'ve got a small kerb outside my flat which I just drive up on to. Job done!!
Work hard, play hard house :D
Adriansturgess
Have you had your tracking checked recently?  :Giggle
trotter
Lol, that would explain a lot actually....
Hehe, nah - it\'s a wee raised thing, kinda like the block paving stones you get in driveways but only an inch or so high and its cambered both sides so easy to drive up on. All i need to get a proper jack under car! :D
