Over 380bhp FC Club
Started by L18M, March 12, 2009, 12:45:58 AM
L18M
Quote from: Jürg Hensdiek;590733Glad to be a service. Pleäse find a link to the Project thread Jöhn started and ran during the build. Much good write up, and unique changes. John is äwäy ät the moment, but the car should be over in the UK sometime this year. Ã,,lso the car häs been invited to compete in the Dutch Time Ã,,ttack series.:Giggle
http://www.mazdarotaryclub.com/forums/showthread.php?t=37167
Enjoy
J
nice link cheers =)
L18M
flik: i got a fcd somewhere.. if you need.. if i can find it! lol
send me an email if you interested
L18M
88GT-R has a stonking fc!!!
jus had a read of the project thread!
anyone know what front bumper he had before the RE one he got now?
http://www.mazdarotaryclub.com/forums/showthread.php?t=37167&page=7
i prob know what it is but im jus bit blur past week as its been a monday since the start of the week!!
mukumu kurubushi
At what point should you upgrade the radiator? I know it a good safety mod to have anyway, but at what kind of power does it become neccessary?
antnicuk
i ran the stock rad (well ducted) with 460 fly on track in all temps and for prolonged periods including drifting.  Just dont stick a big FMIC in the way.  The stock fan works better than any electric one also.
Jürg Hensdiek
Quote from: L18M;59079388GT-R has a stonking fc!!!
Hällo
Originäl was RE ämemaya Pro cowl.
Also, Be ädvised not to run your stock turbo above 12psi for much time. The heät creäted by the compressor loses you power, but importantly the turbine shaft starts to overspin itself at about 12.5psi:Nono!
J
rx7pat
ok just found the mag
Engine
13B- RE eccentric shaft modded oil jets
Late spec 13B REW side cleance rotors
Extended Ports
Ported upper and lower inlet manifold
Sard pressure reg
Trust T78-24D tub
Trust Type R wastegate
RotaryEnergy 4" Down pipe and exaust
RotaryEnergy V-mount intercooler setup
Twin oil coolers
2 x 1200cc injectors
2 x 1000cc injectors
Microtect ECU
Innovate LM-1 wide band sensor
RX8 Gearbox
Re-Amemiya Pro R twin-plate clutch
Torsen LSD
235/45 front tyres
265/40 rear tyres
Cusco Zero-R coilovers
Re-Amemiya FD big brake kit
Seam welded bodywork
Thats most of the important stuff, oh and it was a limited edition Anfini.
Furb
Quote from: Prof;590723Furb actually had a guy that could recode the stock ECU\'s - but he\'s no longer available apparently.
indeed, unfortunately no longer in the ability to provide any service to the Rotary world...
last year i got 320hp and 440Nm on stock port and stock turbo.
hoping on some more now with the new setup :chat
L18M
cheers rx7pat :)
i guess theres no much to rotary engines unlike those piston things.. with cam shafts, valves etc to change
to me.. seems as if you know how to mod piston engiens then rotary should be just as easy as if your not takeing the enigne out or doing anything to it then its jus turbo, injectors etc whch piston cars have also..
L18M
anyone got an email for jon (88GT-R)
i quite like his phat GT chicken wing along with the way he attaches it, nicer than the others i\'ve seen.
or anyone else know where i can buy that setup from?
thanks in advance :)
Jürg Hensdiek
Hällo,
I cän get a messäge to him. Ã,,bout the wing, it is Buddy Club änd custom mounted. Also, severäl chänges since the feäture.
JIC Coilovers
T78-34D
Reworked 4\'\' RotaryEnergy Exhäust system with wästegate muffler.
SuperNow solid links/bushing
SuperNow Lightened Hubs
Full under Chässis Ã,,ero
The cär häs been invited to compete in ´the Dutch Time Ã,,ttack Series later this yeär.
Regärds
J
C-Rex
Have no Idea what to expect from mine but carl will be over in two weeks as far as I know so will be getting mapped and dyno\'d then:mmmm
L18M
Quote from: C-Rex;592340Have no Idea what to expect from mine but carl will be over in two weeks as far as I know so will be getting mapped and dyno\'d then:mmmm
was gonna say i got a proper thread in the members project link but u need to be a full member for that.
only got 1 entry so far lol
hope u get some healthy figures aft ur mapping :)
beezy
