Grinders priced clutch slave and master cylinder.
Started by TiddlesRX7, March 05, 2009, 08:00:00 AM
TiddlesRX7
Does anyone know where I can get Grinder friendly prices on clutch master and slave cylinders for my TII. I swapped my slave cylinder out last year for a second hand one and all seemed well untill now. Think it may be the master cylinder but I may as well swap both out for new ones I think. I\'ve tried my local motor factors and they are both around £50 plus VAT, and Ebay well I don\'t want to go that route unless I have too. Can they be the same on another car perhaps?
Mazdarotaryparts
We have both rebuild kits on the shelf, slave £19.21 and £19.47 master both ,
£2.00 for delivery and you have a total of £46.79 inc vat delivered,
This is the only way this can be done cheaply
Hope this helps,
REgards
Clive
Mazdarotaryparts
Racingbeateurope
Racecarbattery
shyauto
dthebuk
£46.79 is under £50
thats grinder friendly by definition!!
:burnout
Apologies for the thread hijack, but do sell a rebuild kit for Brake Master as well Clive ?
Mazdarotaryparts
Quote from: Prof;589030Apologies for the thread hijack, but do sell a rebuild kit for Brake Master as well Clive ?
Rebuild kit is available at £94.52 plus Vat
Cylinders are different on the convertible to the Coupe / £264.69 and £223.61 plus Vat
All are special order
REgards
Clive
Mazdarotaryparts
Racingbeateurope
Racecarbattery
shyauto
TiddlesRX7
OK so whats the consensus on re-building the cylinders I\'ve got? Is it worth it or are they likely to go again. As in are the bores on the cylinders prone to wear making a seal kit a tempory fix as such, or are they pretty good and re-building them will be fine?
Rotaryguru
Quote from: TiddlesRX7;589040OK so whats the consensus on re-building the cylinders I\'ve got? Is it worth it or are they likely to go again. As in are the bores on the cylinders prone to wear making a seal kit a tempory fix as such, or are they pretty good and re-building them will be fine?
It\'s usually the rubbers that go - so the rebuild kits should do the trick.  You need to be very clean when you do this - as any grit in there will give big problems.  If you don\'t fancy doing the rebuild - then get some new/rebuilt ones
TiddlesRX7
I don\'t mind doing the re-builds I had just heard that it can be a waste of time. Just waying up my options really.
Brett
Brap Brap Brap Brap
David Nock (RIP)
Quote from: Prof;589049It\'s usually the rubbers that go - so the rebuild kits should do the trick.  You need to be very clean when you do this - as any grit in there will give big problems.  If you don\'t fancy doing the rebuild - then get some new/rebuilt ones
Yep... And all cleaning/lubrication of internal components on assembly has to be with clean brake fluid - nothing else.
Hydraulic work is like hospital surgery (I think - never having seen any surgery \'cos I\'d faint!) pull and push the bits around, then sew it all back up, but you\'ve got to be spotlessly clean in the work area.
Sadly Missed
TiddlesRX7
grinder
should be ok with a normal seal kit - i think i did a write up about it somewhere :D
The tightest man on earth
:Giggle
TiddlesRX7
Thanks guys, I\'ll let you know what route I go and the results.
t2rew
i got a new mazda master. never used. £50
