Apexi powerintake small tube/bushing/pill?
Started by AndersE, February 23, 2009, 12:10:20 PM
AndersE
In my kit there are a small ca 2cm diameter tubepiece that according to jap instruction is to be inserted in the tubing to the upper filter.
What is this piece for, and won\'t it slip around in the tubing?
yehreally
It definately will not slip around and may find it difficult to put in and the pipe usually has to be cut to remove it.
its something to do with air restriction and creating pressure/vacumn.....stopping too much air  :rolleyes:
this is probably the most unhelpful reply you will get :Giggle
AndersE
Ok, do you know what happens if i don\'t put it in?
yehreally
I have used with and without...no noticeable difference.
If its the tube that goes to the airpump then I suspect it may alter the emmisions for the worse :2eek
Ricco_04
Its to restrict the famed \'mooing\' noise that you get when using cone filters, with the airpump still active :)
AndersE
Ahaaa.. good to know. Thanks for replys..
gandyRX
i had that bit in mine, didnt install it but it still sounds good
Nik da Greek
Quote from: gandyRX;587990i had that bit in mine, didnt install it but it still sounds good
Hahaha! I didn\'t have that bit with mine, so also didn\'t install it, and it sounded like a Friesian cow! :Hammer
