Fitting Dual SBC ??
Started by rx7boy, February 17, 2009, 10:56:31 PM
rx7boy
Hi Everybody,
Was out fitting the dual sbc boost controller today and noticed the small metal
bead inside the tube from turbo outlet into actuator, Im running my stock twin
turbos non sequencial so only have the one actuator. Just wondering with the
new boost controller do I still need to put metal bead inside tube or leave it out?
and if I do keep it which tube does it go in from turbo to solenoid or tube back
from solenoid to actuator ?
thanks
DM-Motorsport.co.uk
rx7boy
DM-Motorsport.co.uk
