K Seal
Started by L18M, February 15, 2009, 03:24:48 PM
HaywardRotary
Don\'t expect instant results with the product,it can and does work even on some pretty bad cases.
You need to run the car for a few day\'s with the K seal in the coolant and keep coolant topped up whilst doing so. After a while it should work.
I used it for 18 months in an FD that had bad problem, and after 18 months pulled the motor even though it was still running fine and it had a cracked plate with a chunk of the metal missing and the inner water seal had popped though.
I am not saying it is the best route as rebuilding is,but if it gives someone time to save for a rebuild then that is where it comes into it\'s own.
Regards
Carl
Single turbo conversions.
S
