Erratic idle when air con switched on
Started by ScuttleRX, April 07, 2004, 10:43:43 PM
ScuttleRX
Used my air con for first time in a while today and the idle kept dropping to around 500 then back up and down and so on.
I changed the battery a few weeks ago, thinking it might just be the PFC needing that initial set up again where it sorts the idle out. Does that sound likely?
maximtaylor
Yes, it should settle. Just leave it at idle with air con on for about 10-15 minutes.
Regards
Max
ScuttleRX
davefrith
Mine did that before, but now I\'ve got it back will see if its still doing it
