Will any HKS FCD work with my PFC F-con?
Started by Jimi_Hendrix, February 09, 2009, 12:18:55 PM
Jimi_Hendrix
Got a chance at an HKS FCD that was once fitted to a Toyota Celica or Starlet or something.
Will it work if i hook it up to my PFC F-con? They arent model specific are they those FCD\'s?
Cheers!
Looks like some will, but not all:
http://www.hksusa.com/products/?id=683&rsku=4279
If it was on Celica or MR2 then it\'s the same device - just change the setting knob to 2 (from 7)
Jimi_Hendrix
Quote from: Prof;582749Looks like some will, but not all:
Yeah it was on a Celica GT4 Thanks again Prof! :Thumbs-up
Jimi_Hendrix
It was on a Celica GT4 but it was the ST205 model made after 1993. The HKS website link you gave me there states UP TO 1993 So prob a diferent thing.
L18M
my fcd will fit all TII and any ecu :p
correct me if im wrong but they all do the same thing. that is after stock boost, the fcd just tells the ecu its at max boost even if it is over stock boost.
eg max boost is 8psi, at over 8psi the fcd tells the ecu its still at 8psi.
(you can see i need the money for my rebuild) :Giggle
Jimi_Hendrix
Quote from: BBCFC;582775my fcd will fit all TII and any ecu :p
Ha ha! Yeah! They all do the same thing its just i figure it would be cool to have all HKS stuff you know, that and it was quite cheep. But tbh i\'m prob gonna end up buying your one man! Lol! Just as soon as i have free funds!:chat
L18M
Yeh, b nice to hav all hks stuff!
But all adds up lol.
I\'ll stop my \'occupational hazzard\' now! I use d to b in sales, still kinda am lol
They do all do the same thing - but some do it better than others.  What they should do is keep the signal exactly the same until a point is reached, then maintain the output at that point.  What most of them tend to do is alter the curve or line so that an error is introduced in the fuelling which gets worse as the boost increases.  It\'s possible to correct some of that error by compensating for it with fuel pressure increase - an adjustable FPR with a rising rate can do that for you.  Alternatively, you can adjust the FCON to bring more fuel in as the boost increases.
