old problem, new solution? check valves
Started by JohnP, January 30, 2009, 11:32:24 AM
JohnP
alrite guys,
many moons ago i was havin trouble with a check valve that comes towards the pressure tank.. replaced it with a used one, problem solved...and now thats gone after 8 months or so.. where can i get a NEW substitute? rather than having it go pete-tong again.
fil_auto
JohnP
will they push into the existing hosing ok? i noticed it said for use with silicon.. and the rx7 original ones can be a little stiff and brittle!
fil_auto
well if your gonna change one of the check valves - you might as well buy a bit of silicone and change it too..... that\'s my plans for tomorrow anyways! #;o)
Quote from: JohnP;579791will they push into the existing hosing ok? i noticed it said for use with silicon.. and the rx7 original ones can be a little stiff and brittle!
FEED Addict
Nice to see you are keeping busy!
Quote from: fil_auto;579792well if your gonna change one of the check valves - you might as well buy a bit of silicone and change it too..... that\'s my plans for tomorrow anyways! #;o)
