acv removal
Started by rx-paul, September 25, 2006, 10:29:06 AM
Scott Zimny
How did you manage to get the 3rd nut off of the ACV??
I can\'t seem to get any room in there to turn a small spanner around?
Is it just the 3 nuts holding it on??
wow
When removing the acv do you take of the solenoid aswell or just bolt that somewhere els and leave it connected ?
also the vacume pipes that you disconect do you blank them off or can you just leave them open ?
thanks
RobbieRX-7
Keep the single solenoid, just make a bracket and fix it elsewhere.
As for the pipes that used to go to the acv, it\'s preferable to remove the associated solenoids (2) but you can blank them off if you want. Just fold the pipes in half and cable tie the ends to make them air tight
meddy
Sorry to resurrect an old thread, but Im just going through this process myself. Ive got everything off and the blanking plates in place, but I have a question regarding the solenoids. Are they ok left in place but just venting to the atmosphere, or should I unplug the electrical connectors. Seems a lot of effort to physically remove them.
Cheers....
DR SCHNITZEL
Id like to know this too. Also id love templates for the blanking plates so i can get some made myself.
meddy
Quote from: DR SCHNITZEL;529552Id like to know this too. Also id love templates for the blanking plates so i can get some made myself.
Unless you have access to a milling machine its probably cheaper to buy them from somebody. I got mine from Ed RX7 on here for £30 including bolts. Quality and fit is excellent.
RobbieRX-7
You can buy templates for about £25-30, or you can make your own. Just draw around the parts that you take off and transfer that outline to some aluminium. You wanna use some 4mm+ thick ali though. As for the solenoids being left in place, it\'s fine as long as you make sure there are no pipes venting to atmosphere.
DR SCHNITZEL
cool ill do that, i have friends who want to see a smile on my face again that will do this for free. owwww! cheers all. just thinking unless you want to save weight theres no point in removing all this stuff is there, any cooling effect will be negligible surely?
DR SCHNITZEL
so ill prob leave it all on. god im wasted tonight.
rxheaven
I know this is an real old thread but anyway. Where is the acv in the pic is it the whole chunk above the LIM, as my blanking kit has 4 pieces and I dont know where they go
