Odometer stopped working?
Started by leeroy_25, January 18, 2009, 05:14:36 PM
leeroy_25
I have an FD3 (1993). I was coming home the other day and noticed my odometer was not working.. the digital display was not there although the backlighting was.. Aslo the speedo was still working fine.. When I stopped in some traffic it came back on momentarily and then hasn\'t worked since?? Has the speedo packed up or is it a dodgy connection or fuse or something?
Thank you
Lee
This sounds like one of the plugs that go directly into the back of the dash loseing a good connection,
I have the feeling that if you give the wiring a wiggle it will come back on, if so long term it could do with coming apart but that\'s up to you,
Hope  this helps
leeroy_25
Thanks Clive i\'ll have a fiddle and see if it comes on again...
