ABS Warning Light
Started by C J R, January 18, 2009, 03:33:06 PM
C J R
Hi all,
I\'ve tried to search for related threads but with no luck, can someone help me ?
RX failed its MOT as the ABS light is flickering on and off.
All sensors look okay as do the wires (to the best of my visual inspection).
Any ideas how I can cure this problem ?
Many thanks
Chris
Draco
I had a similar problem....  Check the Fluid level that is what it was for me
Other than the above the only time I have know this is when an ABS  wire somewhere on the car has chafed though and was shorting,
C J R
Draco & Clive, thanks guys.
I guess I should have checked the level first. However the sensor wire on the turbo side is exhibiting a slightly burnt/bilstered outer sheath, so hopefully replacing this one should cure the problem.
Chris
dixgomez
Yeah, I think you should check the sensor and replace some cables....
__________________
From Busby SEO Test
