help with greddy ext wastegate..
Started by karl_tate, December 21, 2008, 03:07:10 PM
karl_tate
i have taken my external wastegate apart today and found that im running the yellow spring, which i think is the 11psi one.
i was getting a little bit of creep before but now i have found that the diaphragm has a few little holes and marks where it has worn.
just wondered where i could get one, and if i need a new one?? could this of been causing my boost creep some times??
cheers
karl
____________________
XBOX GAMERS TAG --- tatey1985
antnicuk
holes in the diaphram are not good, your lucky you only had creep.  Did it cause your engine to pop?
Definately change it, i\'m not sure where you get another one from though
karl_tate
no was not the cause. it held fine most days.
are we talking about the same one, not the black one, (i really dont know much about wastegates) its the orangey colour one inside when you take the spring out.
i did think about taking a photo, will get one uploaded.
antnicuk
the black one?   normally a rubbery thing sandwiched between the lid and the body of the w/g under the spring
karl_tate
yeh that the one, thanks. the black thing i was on about, the side that bolts to the take off from the manifold.
so any idea\'s guys where i could get one??
thanks
karl
karl_tate
karl_tate
Fats
have you tried RHD japan? there fairly good
karl_tate
