X-02 relay and fuse box
Started by karl_tate, December 13, 2008, 03:09:27 PM
karl_tate
well have been doing a bit more today and stripped down the main box.
could some one please tell me what these fuses are as the cover has worn down.
ive got
BTN
B1
DEFOG
ABS
COOLING FAN
what is BTN??
under them have
audio
air con
abs
?? (carnt read this one)
(TEL)
what is TEL??
cheers guys :Thumbs-up
____________________
XBOX GAMERS TAG --- tatey1985
FD3UK
I have attached a couple of pages of US spec wiring PDF which is found dotted around the interweb.
First one shows main circuit diagrams, second one shows X02 wire colours.
As you can see bottom two fuses are not used on US spec. but X02 box I have has wires going to bottom fuses so must be JDM specific. Cant help you on what they do.
BTN is a main feed for battery circuits. B1 and B2 both feed the ign switch.
karl_tate
thanks for that :D
just the other two i dont know what they are or do? TEL and the one above
cheers
karl
karl_tate
bump, still dont know what they are??
