Low Manifold Pressure after new Rebuild
Started by captainlovepony, December 16, 2008, 09:09:40 PM
captainlovepony
Hi people,
Please help, im still having problems with car after new rebuild.Now have Low Manifold pressure which is causing hunting and bad running, anyone know what i can do?Your input would be most welcome.
Thanks guys
Jono FD3
there is a bleed screw under the intake manifold... not sure if this could cause the problems you are experiancing?? has she been mapped or roughly set up since the rebuild??
Jono
nikp
hunting is usually caused by an air leak in the intake system. Would explain a low manifold \'pressure\' (Which is actually vacuum on idle!)
