compression test
Started by richrx, November 30, 2008, 10:37:19 PM
richrx
too late flights are booked:Hammer i might email him and see, would save alot of faffing around.
what specialists are around kent, Rotechnics are no more i hear.
richard
p.s whos already seen his car in the flesh?
I\'ve seen the car at Rotechniks - he spent a lot of money getting the bodywork sorted, and it shows.  A good clean example.
Don\'t know much about the engine.
grinder
i have seen it in the flesh and its a very nice example
the guy who sprayed it came to my house to look how it should look and he seems to know what he was talking about !
The tightest man on earth
:Giggle
richrx
he seems genuine about it, so i dont see any problems with buying it :) cant wait to get anothe rex!
so any specialists near by?
richard
DMDRIFTING
Quote from: richrx;561686dmdriftion - do you know the answers to these questions? afaik a cold compression test will give a higher result, giving better readings than the engine has, as compression falls when its warm, hence worn engines starting from cold but flooding when you restart it once its hit operating temp.
richard
Ah ha this will explain the plume of fuel smoke on start up once warm, just on the off chance how long will an engine run for in this state before it goes pop?
I\'m gutted
richrx
is it water seals? my Fd poped about 3 weeks later, but the FC shouldnt go pop(so i hear), keep it toped up with water so it doesnt run dry and overheat.
i\'d be tempted to buy head gasket sealer from a car shop(like rad weld, but for the hg), see if that seals it for a while longer too, only a few quid. If the  engines struggling then it cant hurt surely?
richard
richrx
Quote from: richrx;562065i\'d be tempted to buy head gasket sealer from a car shop(like rad weld, but for the hg), see if that seals it for a while longer too, only a few quid. If the  engines struggling then it cant hurt surely?
p.s please check into this more before you do it, and never believe all you read in an internet forum :Hammer
my mini disclaimer, just incase!!!
richard
DMDRIFTING
Geoff thinks its a sticky seal, hence letting in more fuel to the following chamber, hence the grey/white \'high octane smelling\' smoke on start up ha ha
Going to get it rebuilt as it won\'t be to bad or cost tooo much fingers crossed
Thanks for help too
Quote from: richrx;562065is it water seals? my Fd poped about 3 weeks later, but the FC shouldnt go pop(so i hear), keep it toped up with water so it doesnt run dry and overheat.
richard
Putting anything temporary like that on a performance engine isn\'t a good idea, thats a bit like using gaffa tape on an F1 engine, sure it might work for a bit but won\'t last long and will do more damage when it fails.
