uber negative camber on coilovers
Started by L18M, December 05, 2008, 11:53:11 AM
royal
Looking at those bits mate, it looks like the single middle vertical arm does the camber by moving the subframe up and down. The black replacement bit is an alternative that looks like it give you more adjustabily and you can adjust whilst its on the car as well.
The two purple arms that go out to the hubs are lateral arms that adjust the toe in/out of the rear wheels.
You\'d probably be better off getting both the lateral arms and the camber arm thing because they work together. If you get just one of the items you may not be able to setup the suspension to its best alignement ie you may find if you just get the camber adjuster that you havn\'t got enough adjustability and you\'ll end up with bumpsteer. This is when the toe of the wheels changes as the suspension goes up and down. Buying adjustable lateral (toe) arms means you can sort this out.
L18M
Quote from: royal;562975Looking at those bits mate, it looks like the single middle vertical arm does the camber by moving the subframe up and down. The black replacement bit is an alternative that looks like it give you more adjustabily and you can adjust whilst its on the car as well.
ah.. gd read =)
but whats the big flat round purple things..?:confused:
royal
#32
Diff support bushes
L18M
Quote from: royal;563154Diff support bushes
thx thx =)
im guessing i dont need them...:confused:
