misfire on single turbo,fresh rebuild
Started by a.tapos, November 25, 2008, 08:05:08 PM
a.tapos
not yet,good shout,ill do that tonight might volt drop check the coil wiring too:bandit
a.m.t@hotmail.co.uk
shaunwil
Usually a good sign if one of the cells have gone bad in battery. This weather usually finishes off batteries.
Shaun
a.tapos
Right checked earths and volt/drain,all ok,noid tested all the coil wires during crank and checked for spark all ok,
got it running though crap idle and stinks of fue heat light on again,
lnitially revved ok so had another check for leaks,this time i noticed a slight exhaust blow between turbo manifold and down pipe(before o2 sensor) so now believe this may be my fueling problem,looks like a crap job to re seal though,
Fingers crossed.:god
a.m.t@hotmail.co.uk
