spark plugs..... what do you use
Started by cyman, February 26, 2008, 11:32:25 PM
Mazdarotaryparts
As said above 9s are the ones you need,
You only ever need hotter (7\'s or 8\'s) if you either have an engine that has low compression that floods or you only go 1/2 a mile to the supermarket
You defiantly don\'t want any colder, indeed if you run 10\'s or colder you risk the car not firing up on a winters morning
Here is a link if you wish to buy 9\'s , I am told by our customers that we are the cheapest around for these plugs
   http://www.mazdarotaryparts.com/bfd-si013-ngk-bur-9eq-spark-plugsb-759-p.asp
Hope this helps
REgards
Clive
Mazdarotaryparts
Racingbeateurope
Racecarbattery
shyauto
neil_jdmr
306 bhp and 9\'s allround with a hiccup
prince_of_tokyo
i run 10.5\'s in summer, but now as the weather has got a little chilly have switched to 9\'s all round as advised by clive and laeeq and it runs spot on...
Malik
WAS;
1994 FD3 Type R-II
all TRUST/GREDDY prepared
T78 blower
big street port
500bhp
one happy driver... :yes
NOW;
Porsche 996 C4 CAB
20B_boy
Try sparkplugs.co.uk, they are usually the cheapest and deliver uber quick from experience. Note that there are BUR9EQ and BUR9EQP, the latter being the more expensive platinum variety.
R.
joshrulz
Quote from: Lum;479213I use 2 x B9EGV & 2 x B10EGV NGK plugs, running about 400bhp, did switcg to 10\'s & 11\'s but they had a tendancy to foul up if i was sat in traffic for too long!
same setup as me.  i actually had b9egv in the top but when i cruised along in 4th or 5th around 60kms the engine would momentarly completely die and fire back up straight away with in a second. so put b10egv in the top and problem fixed.
there are cases of these egv plugs braking the ground electrode but very few, just dont use iridiums as they a fuse welded together and the rotary gets hot enough to make fall apart
