Removing PPF
Started by SiH, October 15, 2008, 11:23:07 AM
SiH
How the flip are you supposed to do it?!?!
The four bolts that attached to the GB housing are off, and the 5 that attach to the diff - i was trying to do this in the half light last night so I\'m probably missing something - do i need to drop the prop first? It seemed like it was catching on something?
Laeeq
yes, you will have to drop the prop first but dont let it come out all the way from gearbox....the oil will be all over the place.:2eek
Laeeq
SiH
Cheers dude :)
I\'m going to drain the box first anyways, and drop the rear end.
So i need to support the box or will it be ok hanging on the mounts?
Laeeq
its better and safer if you support the box.  What are you replacing? the box? or the diff?
Laeeq
SiH
Sweet, cheers.
Stripping the underside of the car for longivity treatment and rebushing/blasting the subby and all of the suspension components :)
