Going Single...what do I keep from the Rats Nest
Started by gonzoninja, November 18, 2008, 08:53:20 PM
gonzoninja
Got my single turbo. Got my secondary fuel rail and injectors.
Started pulling bits off.
So anyway what do I need to keep from the Rats Nest? If anything? Surely all I need is the solenoid from the boost controller to open the wastegate. Or am I being thick and not understanding engines.
Pictures of stuff I need to keep would be nice.
Ta muchly.
Cashpoint
From My understanding all of the rats nest goes leaving as you said pipe from compressor housing to boost controller and boost controller to wastegate
karl_tate
get rid of it all, you will also have to do something with the double throttle, i just pulled the pipe off.
need fuel pressure regulator, map sensor, boost controller/wastegate from the top of my head
____________________
XBOX GAMERS TAG --- tatey1985
gonzoninja
which bit is the double throttle? The actuator thingy on the plenum?
philiwily
karl_tate
gonzoninja
Cool. Thanks Guys, I guess I can probably figure it out.
karl_tate
yeh thats it, i didnt know where to start or what to take out, just ripped the whole lot out :D
