Question about intercooler hoses
Started by Ada7, September 12, 2008, 08:26:48 PM
Nik da Greek
#15
Cant remember what size I/D the cooler hoses are? Have a feeling its 70mm, but thats from memory. Looks like it may be tricky finding Superflex that big, but Viper Performanc go fairly large with it, and do say that they may be able to make bespoke stuff, could be worth a go....
http://viper-performance.co.uk/productsearch.php?cat=2967&mat=104
SFS seem to do it in their wire reinforced range in really big diameters, though;
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=SFSSHL6.5
Or failing that, some wire reinforced hump hose connectors may prove to be of use...
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=SAMXCAC51B
Ada7
najiru i\'ve PM\'d you about the Greddy pipe :)
Adam
I AM HERCULESIAN
najiru
Pipe arrived, nice and shiny! Thanks mate :D
Ada7
No worries. Hope you can make good use of it :D
Adam
I AM HERCULESIAN
If you still want a piece of straight pipe, I may be able to help...  I have a straight length of 75 mm ally pipe, plus some bent lengths too.  I\'m only over in Farnborough, so if you wanna pop over at the weekend, I\'m probably able to help you out...
mail me at archbish at gmail dot com if you want, or text/call me on 07775665136
Ada7
Thanks Bish but i\'m all sorted now :D
Unless you have some gaskets you want to part with. Ones between the TB and plenum or the Plenum and LIM? :)
Adam
I AM HERCULESIAN
