What temperature should a twin turbo run at?
Started by gandyRX, September 18, 2008, 04:05:55 PM
Steve-Q
Quote from: FDAsh;53843485 water and 50 on air is normal for me.
Nice cool nights recently here though, so make that 83 and 32 :)
:eek mine runs 85 water and around 20 - 30 air intake,
RemarkLima
Quote from: jonny116;538583Ahh really, i just thought i had an overly good cooling system, ha.
Is it easy to check yourself?  I thought 10 mpg was a little on the steep side steep!!
It\'s the only thing I can think it\'ll be... Unlikely to be a gammy sensor or you\'d never see the range of temps.
But the only real way to check is to pull it out and put it in a pan of boiling water and watch it open. But then for the few quid for a new Thermostat you may as well stick a new one in while you\'re at it.
That said, it looks like a total behatch of a job.
RobbieRX-7
It\'s really really easy to replace the stat. 3x10mm bolts, remove the upper hose and the whole filler neck comes off. No need for sealant. Just buy a new stat with surrounding O ring. Will take no more than 20 mins and a tenner.
Jono FD3
My temps are sitting at a rock solid 73 and 20 - 30 intake on my V-mount but the cool water temo could be down to having no undertray between the bumper & subframe so the rad gets max air flow all the time!!
Jono
nikp
Quote from: Jono FD3;538651My temps are sitting at a rock solid 73 and 20 - 30 intake on my V-mount but the cool water temo could be down to having no undertray between the bumper & subframe so the rad gets max air flow all the time!!
Jono
73 is too low mate. Engine is not running at peak efficiency at that temp, and as said above the ECU is going to chuck in extra fuel when it\'s cool
FDAsh
Quote from: Steve-Q;538587:eek mine runs 85 water and around 20 - 30 air intake,
Yeah but you have a big old FMIC on there don\'t you? I\'m still on an SMIC behind the rad.
Jono FD3
Quote from: nikp;53865773 is too low mate. Engine is not running at peak efficiency at that temp, and as said above the ECU is going to chuck in extra fuel when it\'s cool
Got a sneaky defusor plan going on in my head at the mo which will sort all these problems out, along with giving me downforce ;)
Jono
