DV26 Dump valve?
Started by MarkoFu, September 06, 2008, 09:46:53 AM
MarkoFu
Hi guys,
I\'ve taken a the Baileys DV26 dump valve off of my old car with the intention of fitting it to my FD. However, the HKS one i\'ve taken off has a much smaller fitting to it and as such the DV26 won\'t fit in the tube. Is this a sign that it\'s not meant to be fitted to an FD or is it simply a case of getting a larger tube and making it fit??
MarkoFu
BUMP BUMP!
Any advice on this one please? :)
mark-ashley
#2
I have a Bailey Motorsport Valve which i am intending to put on today if i can get the bloody hoses off....
The Bailey one will fit but you will need to buy a fitting kit which consists of a blanking plug which goes on the hose to your airbox (if you have one) and a reducer pipe, the smaller end going to the car and the larger end going to a piece of tubing that comes with the kit that the valve then fits onto...
All are fastened with supplied jubilee clips....
Or you could just get a larger tube but if you have an airbox as opposed to an induction kit then you will need the blanking plug, whole kit is about 30 quid...
1993 FD3S - Street port, Decat, Apexi FC, Apexi Induction - Engine rebuilt and installed by Hayward Rotary, too fast for the mean streets of Croydon !
mark-ashley
The parrt number for the fitting kit is FK51
