main hub bolt
Started by pigeon, September 05, 2008, 05:52:42 PM
pigeon
aaaaaaaaaaaggggggghhhhh!!!!!!!!! what have you guys used to remove the main hub bolt. iv tried big breaker bars and my 240v impact gun and it aint coming out! what size impact gun are you using to get it out.
cheers adam.
antnicuk
heat is the answer my friend..........blow torch all around the front hub, you will need to replace your oil seal though
pigeon
Quote from: antnicuk;532749heat is the answer my friend..........blow torch all around the front hub, you will need to replace your oil seal though
yeah i tried a little heat but not too much because the ****ing gas ran out.lol. im doing a full rebuild so the seal aint a problem. will try again tomorrow with more heat and if that dont work then its time to bust out the 1" drive gun from work.
cheers adam
