will this clutch cope...
Started by karl_tate, August 21, 2008, 06:27:59 PM
Dr-Rotor
I use an Exedy twin plate carbon fiber D core with light weight flywheel. Not sure how much they cost over there but if you every wanted to increase your boost this clutch can take it. I use this clutch for daily driving & racing. Its insanely smooth for the street.
As said above you do need more revs to take off but the clutch dose not grab like those puck setups do. This clutch is the best you can get. The D stands for Damper...it helps protect your drive line on hard launches. Another cool thing about this clutch is that the hotter it gets the more it grips. Smooth for the street & designed for racing. If I remeber correctly it can handel over 650hp.
They cost about $3000 NZ so I guess about 1,150 GBP.....well worth the money.
karl_tate
cheers clive,
will get my self organized and most probably order one :)
dr rotor, well worth the money if you have it :p lol
____________________
XBOX GAMERS TAG --- tatey1985
Dr-Rotor
