electrical fault
Started by Ste C, August 16, 2008, 02:28:17 PM
Ste C
Hello all.. The electric windows on my 93 Rex have a problem. When you press the switch of either window the windows drop an inch, stop, drop another inch, stop, they do this until there fully open. Also my seat belt light flashes when the belt is clipped IN. Both problems started at the same time, Sounds like something simple, Any ideas before I start pulling things to bits, Cheers people.
RobbieRX-7
F100 ecu located behind the dash. Easy to change and a common problem on these cars. Will cost about £25 used
Ste C
Will give that a try, cheers mate.
Ste C
Fitted a new f100 unit and all is well, cheers for the advice Robbie,
