Injectors or fuel pump ???
Started by neil_jdmr, August 27, 2008, 04:54:58 PM
neil_jdmr
Getting a re-map with a decat,nur spec and filters and maybe a side mount ic.
Will i need injectors and/or fuel pump upgrades too?
The reason i ask is this "get a pfc" idea is snowballing outta control. I am having to put my foot down and saying i cant afford anything else until after the TAS in january.
neil
gsb876
Shouldn\'t do as no major power hike, if you go single or map for high boost then would be better to upgrade.
