Request from those with 99 spec front ends.
Started by SiH, July 30, 2008, 08:16:54 AM
SiH
Heya ll :)
I\'m after the exact measurements of a plate to fill the \'plinth\' on the 99 spec front bumper - I\'m after a 2 line plate - I\'ve currently got a stupid small plate and I want a near conventional size 2 line job. Don\'t suppose anyone know swhat size they are are?
Ta
Si
michaelb
#1
Quote from: SiH;520616Heya ll :)
Ta
Si
Hello mate
I have a 99spec front.
Have a look at my avatar, is that what you are after?
I have changed mine to the small one, so I went and looked hard for my old plate, found it and here it is:
Length 28.5cm
Height 25cm
Hope this helps
Regards,
Michaelb
SiH
You, sire, are a true gent :)
That\'s just the sort of look I am after (I think, from what i can see! :D)
Legend :)
You should have said, we could have swapped plates :D
Si
Kevin
Standard Japanese plate size for your front bumper is 13" x 6.5" (330mm x 165mm).
Hope thats of some help too.
SiH
Cheers Kevin :)
Now I\'m confused as to why it\'s so much shorter than Michael\'s?
michaelb
#5
Quote from: SiH;520702Cheers Kevin :)
pm me your e-mail address amd I will send you the shot of my plate on the car
Regards,
Michaelb
my mistake it is 20.5 cm in height...the hit is getting to me since my a / c has packed up LOL
REgards,
Michaelb
