Problems with KG parts rail
Started by Timmy, July 09, 2008, 10:39:47 PM
Ed_RX7
well what you Bl00dy waiting for!!!!!
Edrx7Parts
07531 669 768
Also of
Kash_
R1Dude
Hi, anyone got pics or diagrams of the set up for 1600 k g parts rail, bought mine as a brand new kit off ebay but got no instructions, I have fitted it and it does seem solid but as its part of a complete re-build and power upgrade thats not finished yet, I would like to know if I have fitted it right before I turn the key, thanks Ade :Thumbs-up
mx1311
its simple dude, just make sure you dont pinch the rubbers at either end of the injector
use a little vasalene and you shouldn\'t have any probs
R1Dude
karl_tate
i had a little problem with mine, fitting the fuel lines, they would not seal and it leaked from either end, tried all sorts but ended up using some resin which solved the problem.
other than that it was all good :D
whats the secret kash??
____________________
XBOX GAMERS TAG --- tatey1985
Kash_
ummmmm.... lets just say 1.2 :D
karl_tate
cool, get the spec and new vids up once done :D :D
Timmy
Quote from: BlitzBoy;515843Or use Gary at Rotaryarts his fuel rails of a different design but will let you use the 1680 top feed injectors
Thats what i was considering but jason rang me back before i had a chance to order with an idea of developing his own rail of some kind, so thats what i will be haveing. I wonder if he\'s decided this cuz he was building a high boost engine when i was in.
20B_boy
Quote from: Timmy;516043I wonder if he\'s decided this cuz he was building a high boost engine when i was in.
Whats he used on high boost engines before then?
R.
DRAGON
Tell him to dowl it then, cus Carl always says that you can go above 1bar without a dowelled engine.
