How much power with this setup?
Started by Aikio, June 10, 2008, 08:09:11 PM
Kevin
Quote from: Aikio;507205Ahh... they\'re still sequential standard twins.
The engine was rebuildt about 15000 km ago... not sure what thats in miles 9500 or so..
9322.56 miles. :chat lol.
Seriously though that dash looks fantastic!....  Possibly the nicest job i\'ve seen to date!  Major hats off to you if you\'ve done it yourself!
Aikio
Quote from: AtomicRex;507282This doesn\'t really have that much effect.  You have a high pressure zone at the base of the windscreen.  This is, I agree, slightly less than a standard saloon due to the decreased rake of the windscreen but non the less it is still an extensive high pressure zone.
This Zone actually contributes towards down force.  Unfortunately it is counteracted by the lift generated by both the bonnet and the roof, but is why you see the faster sports cars with a very shallow long screen as this smooths the transition between the bonnet the windscreen and the roof.
As air moves from a high pressure zone to a low pressure zone, and the air under in the engine bay tends to be low pressure, the air wont actually come out very easily by the windscreen.  If anything it will want to circulate under the bonnet causing drag.
The best way to remove air from the engine bay is either via the bonnet using NACA ducts or under the car between the chassis and a flat floor then exit at the rear into the dead air.
Ok, Then I\'ll throw away that idea... I\'ll just have to wait and see how the temp goes then...
ENVYD: I just used some contact glue from a car accessories shop.. I was a bit unsure of how it would work out, but it worked great...
Kevin: Thanks. I did it myself with a little bit of help from a friend with the dash and doors...
Morten Aikio
- 1990 Mazda 323 GTX
x 1984 Opel (vauxhall in britain)corsa (nova)
maz13b
Dr-Rotor
#18
I have tuned 2 PFC TT-FD\'s here in NZ on dyno dynamics, both had all the bolt ons but not your extra fuel setup. 1st FD made 335whp max tune 1bar. 2nd FD 320whp max tune 1bar. You should be able to make a slight bit more with those bigger injectors. You could if you wanted to probably tune to a good safe street power of around 340-350whp on 1bar & if you trust in your new motors build quality you could reach 360-370whp on around 18psi with hard core AFR tune.
Difference in 99sepc turbos showed up on my girl friends car. Mods are 3" exhaust, PFC & K&N panel filter. Her car made 285whp on 0.8 BAR. Thing is her Exhaust DP is not 3" & so when we increased to 1bar the motor could not push the exsess pressure out & the dyno showed a drop in power. Fliped it back to 0.8 & the power went back up. So next on her list is a 3" DP, FMIC, Alloy rad, & ducted Simota intakes. Then back to the dyno for another tune.
So find yourself a good tuner, a fairly accurate dyno & you will be very happy.
PLease note all cars tuned in the above txt are rebuilt motors with large extended porting, special apex seals & very agressive AFR tunes. I see your motor is stock port so I dont think you will quite reach those higher numbers but you should easily make 340whp.
Keep us posted, I look forward to your results.
Dr-Rotor
#19
If you are worried about intake temp look at installing a water injection kit. That will keep plugs clean, stop detonation & increase power all while droping your intake temp & by keeping the power up even on those hot days your car will feel like you just pulled it out on a cold winter morning. Nice dense air & good power.
Aikio
Figured I should update this if anyone was interrested...  I had some moneyproblems this summer. I paid too much tax last year and was supposed to get about £1200 back, but the government messed up so I had to work a bit to get back my money..
At the moment the engine is 98% finnished... I\'m still waiting on the resistors for the injectors, and some custom fabrication for the fuel preassure gauge.
Hopefully I\'ll be traveling to sweden to get it mapped next week. I\'ll post the results then.
Morten Aikio
Aikio
Oh... and the reason it took so long to build/upgrade is that I dont have a garage or anything, so I\'m a bit dependant on the weather... :P
Morten Aikio
ENVYD
well keep up the good work mate! is the dash done yet?
ENVYD
also mate i forgot to ask! when to started to glue the dash down where did you start on first?
Aikio
All I\'m missing on the dash is the gaugeholder on the center speaker.
And I\'m not sure where to mount the LM-1..
When I started to glue it I started on the top, where the vents for the front windscreen are..
Morten Aikio
Aikio
Well... I\'ve probably blown a waterseal.. so I didn\'t even get it mapped... was on my way to something similar to your MOT and the car started overheating a lot... figured it was either a ****ed thermostat or air in the system, but after plugging the ast and removing the thermostat it still kept overheating, and it suddently got really hard to start when hot.
And when I took out the sparkplugs one of them were wet, and it didn\'t smell/taste like either fuel nor coolant, so I\'m guessing it was a mix of them...
so now I have a project for the winter :P
Morten Aikio
ENVYD
Aikio
Hey... figured I\'d update since I\'m finished with the engine.
Ended up with new lapped walls, and the early model 20b housings which have the plug holes at the same place as the t4 sII rotor housing, so we had to be a bit careful with the ignition.
So the mods are the same as before, just different housings..
This was done at 0.86 bar boost:
the first two are wheel hp, second two are flywheel
Morten Aikio
