front lights replacement ?
Started by sickboy2345, July 02, 2008, 08:35:38 PM
sickboy2345
no worries more is better besides you want to know the same thing..:)
sickboy2345
ok mate all you need to do is take this long red wires coming out of each light and connect them to + on your battery! it works for me!
Bobbit
Cool, sounds like the electronics i\'m good at, lol. Nice and simple. Am i right in thinking the negative/black wire plugs in as normal and the positive/red wire goes to the battery? And on the other light the wires just plug in as normal? Have you got full opperation, ie one comes on on dip, then both on full and does the full beam flash (when you pull the light stork) they both flash?
Rob
:Laugh LOL
sickboy2345
cant take a pic right now so i used this one - it explains what is where connected..
1 - plugged to where the old light was plugged in
2,3 - plugged to each bulb
4 - connected with the + on the battery
now these four wires are connected to my side lights
(i cut the side light wires in half, put a chop block between them and fed the power to these four wires on each side
now i got blue rings when i turn my side lights on (along with side lioghts) then dip i got two inner ones then full beam all four...
think thats what u ment..(cant explain better im hammered..:) )
