Oil level sensor?
Started by Swanny_UK, June 26, 2008, 12:51:33 PM
Swanny_UK
Guys,
Is this the oil level sensor in the sump?  I noticed the connector some while back, and the oil level light hasnt been on to indicate a problem.   In the picture you can see Im holding the connector, and above the subframe you can see the sensor in the sump.
The light came on intermittently some while back but it stopped doing it.  I regularly check oil levels and its never run low.  The oil level lights now on, and I managed to trace where this cable is connected too, and I think its the oil level sensor.
As far as I remember its always been disconnected.  So how is it only coming on intermitantly, and on constantly now?  Also - where abouts in the loom is the opposite connector for this one so I can get it hooked up again?
m4drx
there is one in the sump. plug it back in, if it is intermittent then maybe change.
i have a sump on its own with one in hence why i know :)
fduk.
Swanny_UK
Quote from: m4drx;512152there is one in the sump. plug it back in, if it is intermittent then maybe change.  i have a sump on its own with one in hence why i know :)
I know theres one in the sump.  Its in the picture.  Im holding the connector attached to it. Im sure if I plug it into something then it will change, my point is - into what?
