what does it do?
Started by sickboy2345, June 09, 2008, 10:00:56 PM
sickboy2345
hi all
what does it for? this pipe looks like its been disconnected of something and its blanked off with some silver tape...
nikp
It\'s where the air pump pumps its air. If you have no air pump, it may, or may not, get blanked off.
sickboy2345
i have got airpump....
Jono FD3
You have an air pump... but it isn\'t pumping anywhere as the blocked pipe is the main one from the pump IIRC??
Jono
sickboy2345
ok sorry for noobie question but what does the airpump do? and where should i connect this pipe to?how to do it?
Draco
it does just what it is.... pump air into the cat so the emmisions are down.......as yours is not connected. get a underdrive pully set and take that huge/heavy thing out :P
sickboy2345
but then what about emissions whilst doing MOT?
Draco
well either find a friendly mot tester ;) or if you have the apexi fc commander/ecu you can change your emmissions on there.... be carefull as car will run dam lean. make sure you change it as soon as that probe comes out;)
Quote from: Draco;507244well either find a friendly mot tester ;) or if you have the apexi fc commander/ecu you can change your emmissions on there.... be carefull as car will run dam lean. make sure you change it as soon as that probe comes out;)
cause if it runs too lean, you have to rebuild the engine..
JohnP
more commonly known as the moo pipe :)
