FC starting problem
Started by colin5524, June 21, 2008, 01:59:31 PM
colin5524
ok car has been started every few weeks now i finally am ready to take her into the garage and guess what desnt start, fuel pump is going starter whirrling nicley compression good and all vacume pipes and engine earths checked. No spark all no smell of fuel and all the warning lights are all on. Any ideas:reallymad
David Nock (RIP)
Has it been started several times without going anywhere? If so I would guess it\'s fouled up. Bump start it if you can find a good place.
Sadly Missed
colin5524
well i have found the relay at the side of the drivers wing has been making funny sounds which i think has to do with the fuel system, so will test this tonight.
mpk490p
i used to just start mine let it run upto temp then switch it off, they really need a good run or plenty of revs to clear iuts throat! it could be your fuel relay (as you said) i would pull the plugs clean the up charge the battery etc just give it the best chance before trying it again:Thumbsup! then ring its neck with some nice 11\'s down the street:flamed
Mark
