Cutting a fibreglass bumper!
Started by VishalStar, June 12, 2008, 04:53:39 PM
VishalStar
Hi im wondering how hard it is to cut a fibreglass bumper? I have heard it can be done with a metal angle grinder. Would this be ok. i dont want to crack/damage the rest of the bumper just shave about 2-3 cm off the bottom of it.
VishalStar
Got a quote of 600 for it, which is more than i paid to fit, paint, prep and remould the bumper in the first place. i think the garage doing it is a bit of a joke.
Anyone got any ideas?
turbo boy
Shaving a bit off the bottom shouldn`t be a problem, just make sure the bumper is secure and held down tight. £600? what a bunch of c**ts!:3Confused:spank
kev-yorks
Be very carefull cutting fiberglass wear a good mask. The fiberglass dust particles are hook shaped when viewed under a microscope. Get them in your lungs and your stuck with them for good. As for cutting a small angle grinder and cutting blade will do the job or a pneumatic body saw with a fine blade.
Kevin
Regards Kevin
sickboy2345
mate dont know how thick this bumper is but there is nothing difficult with it, just make sure you cut it straight.
use grinder cutter with a metal cutting plate, and make sure you hold it straightafter that sand the sharp edges down with a sand paper ..and make sure you cover your eyes..
i\'ve done it milion times before and never chipped/cracked anything...
allstaruk
