Fcd
Started by joola89, June 23, 2008, 12:13:49 AM
joola89
Just installed my HSK FCD.
Hopefully wired it up right.
Cut the pressure sensor from the ECU
the green wire with a yellow strip and red dots.
All seems fine.
But the bugger now flames for fun.
Anybody else experiencing the same with a FCD?
TiddlesRX7
Well you know what mine is like but I effectively have 2 FCD\'s on mine as the ecu has one built in as well as the one that is fitted under the bonnet. Maybe thats why mine is running so rich?
Mine\'s built in to the ECU as well - I only get flames / pops when I lift off quickly - seems the ECU is fairly well behaved.
